A hello packet was received that indicates this router and the transmitting neighbor differ in their support for IPv4.
When adjacency checking for IPv4 is enabled, this check occurs before verifying the adjacency subnet. If this is undesirable, disable adjacency checking. Otherwise, ensure that the interfaces on either side of the adjacency are enabled for IPv4.
Warning
%pduType% IS-Neighbor(%vlanName%-%sysId%) IPv4 protocols supported mismatch
| Name | Type |
| pduType | String |
| vlanName | VLAN |
| sysId | String |
